How good is the MWR PFC map?
Started by m1tch, August 16, 2017, 07:43
m1tch
Hi all,
I will be installing my PFC soon - still need to order and fit a wideband - I have a MWR map that usually comes on their PFCs which I have been told is much better than the stock PFC basemap that comes on the PFC as standard.
If I run the MWR basemap would it be safe to run this before I get the wideband fitted or should I wait - I can check the knock levels on the commander and log values on the FC Hako etc.
Anything is better than PFC base map it is only meant to enable you to get your car to a Dyno.
I would think the same could be said of the MWR map safe but not extracting the maximum performance.
m1tch
Quote from: "1979scotte"Anything is better than PFC base map it is only meant to enable you to get your car to a Dyno.
Might try and get it added in tonight although I need to try and find a spare laptop! I know it won't be 100% perfect as it would be mapped for an engine that isn't mine - will just be a better starting point for auto tuning vs the basemap, my guess is that its also meant for US fuel which isn't quite as high octane as ours but will keep an eye on the knock levels etc.
Essex2Visuvesi
If anything its probably a good thing as UK fuel is more resistant to Knock especially if you run Shell Optimax or BP Ultimate
US fuel isn't always as bad as you think they use a different standard there 91 is better than 91 ron would be.
Don't think they can beat Vpower 99.
alancsalt
MWR map ran better than Toyota's ECU on my 2ZZ. No trouble getting to the dyno.   s:D :D s:D
(On the opposite side of the planet...)
Toyota MR2 Spyder, November 2002, Engineer approved 2001 Celica 2ZZ motor and C60 trans, MWR Carbon lined synchro set, SMT to Manual conversion, PPE headers,Fabricated Cat/Exhaust, Power FC ECU
