de-badging!
Started by angryman, August 24, 2017, 05:53
angryman
I have purchased 2 x screaming eagle badges for my 2.
Anyone have any tips for removing original toyota badge from front of car.?
thanks.
Fin
Warm the badges if possible, to soften the glue a little, then patience becomes a virtue. I removed all my badges using the time honoured toothfloss technique. The floss is simply used as a type of saw. You get it in the gap behind the badge, and start pulling back and forth, to break the tape/glue behind the badge.
I found the biggest pain was getting rid of the last few traces of the original glue without damaging the paint.
The roof is down on my MR2,
angryman
Thankyou.
ill get the hairdryer on it.
rgds
peter
White spirit to clean off the glue residue then it will need a very good polish to get rid of the outline of the old badge!
angryman
Thanks for the tips.
i shall polish until its gone !!
angryman
Done it!!
looks fab!
thanks for the tips/hints, they worked a treat.
how do i post pics now that pb has thrown its dummy out the pram?
rgds
peter
ilovejapcrap
I'm using imgur now for pics
Treboeth
Quote from: "ilovejapcrap"I'm using imgur now for pics
l viewtopic.php?p=257299#257299 l
Forum Guide here as well   s:D :D s:D
m1tch
I have debadged the rear, still to take off the front badge and repaint  s:) :) s:)
BahnStormer
Quote from: Fin on August 24, 2017, 06:39
I've not done my MR2, but I've done this several times in the past on other cars and I found that Autoglym's "Tar Remover" took the last lumps of glue off with zero fuss and no rubbing / risk of scratching..... and also I found that a cheap (£10?) hairdryer is a BETTER alternative to a heatgun (which will just soften the badges and will probably damage paint unless used really carefully). I bought mine YEARS ago, but just aim for around 2kW: I can see them for <£10 on Amazon, £12 for a decent brand on Prime if you want to buy a "gift" for the missus after you're done!
Hamezi
looking to remove the Toyota " badge from the back of my Roadster. (Successfully did the bonnet badge and replaced with screaming chicken) does the rear bade have pegs?
Quote from: Hamezi on January 13, 2020, 15:17looking to remove the Toyota " badge from the back of my Roadster. (Successfully did the bonnet badge and replaced with screaming chicken) does the rear bade have pegs?
Nope, assuming they're all standard issue the wording on the rear bumper is just well stuck on.
steveash
After 17 years in the sunlight the paint colour of the rest of my car is a shade lighter than that under the badges. These shadows of the badges won't polish out as there is a gloss coat over the colour. I guess it will even out over the coming years unless I get fed up and put the badges back on again.
