fitting tte spoiler.
Started by angryman, October 6, 2017, 18:25
angryman
Hi
just got tte spoiler back from bodyshop and now in sable colour.
hoping to fit tomorrow weather dependant.
Just a quick question for anyone that has fitted one, what did you use to bond it to the engine lid?
was it normal silicone or that gorilla stuff?.
rgds
peter
Nvy
I believe u need something way stronger in order to bond it. The guys that are on the other forums that im are using sikaflex to bond their type r spoilers to non type r civics. It would be ideal if you can screw or fix it the way it was originally mounted by TTE.
Sikaflex or Tigerseal. Mine was on with the two screws provided and TigerSeal. Wasn't going anywhere.
I wouldn't use anything weaker than that
angryman
Many thanks.
I have the two bolts for the underside so will be drilling the lid ,sikaflex or tigerseal!
appreciate the advice, i will try to source one of the two tomorrow.
thanks again.
rgds
pauls0212
i knew it  had tiger in it ... you will get a txt at 9.30 am as i thought it was too late to send now
red 2003 standard so far
angryman
Cheers Paul
Just got back home from piccys watched bladerunner!! if anyone is thinking about it then let me tell you it is absolute pants! still dont know what it was about .
The plot starts off ok then becomes disjointed and then proceeds to non existant.
i was like a nodding dog on a parcel shelf  s:D :D s:D  .
but dont let me put you all off !!.
angryman
Job done.
Used tigerseal, that stuff is strong!
im happy with it.
measured three times using the template to make sure i was in the right position.
and it sits flush with no gaps.
Dont feel right drilling through your 2s engine lid! but its the correct way .
m1tch
Quote from: "angryman"Job done.
I'm happy with it.
Don't forget to put up photos! Did you fit it in the OEM location or further back?
angryman
Will do m1tch.
fitted in the oem location,
Pics to follow.
Ill give the 2 a bit of a polish before i take the piccys, as you do!!
oh, and thanks for doing business with me, im nearly now at the " just as i want it stage".
got the wheels to do then thats it for a while.( car budget totally gone!!).
m1tch
Quote from: "angryman"Will do m1tch.
Pics to follow.
oh, and thanks for doing business with me, I'm nearly now at the " just as i want it stage".
Its no problem at all, for me I wanted to go with a more streamlined back and reduce the weight as much as I can - glad its gone to a good home and you are happy with it  s:) :) s:)
angryman
Just a test to see if this one is works!
20171011_103948
 m https://farm5.staticflickr.com/4444/376 ... f838_m.jpg m
angryman
try again,
m1tch
Looking good  s:D :D s:D
