Cabin air exaust
Started by edmundopt, November 19, 2017, 02:11
edmundopt
I am pretty sure there is a topic here about it, could not find it, what do you call the side vents air exausts?
I have some questions, are there two?
Where are they in the spare parts catalogue and where are they in the repair manual ?
Can i remove it, or do I need to clean it in place?
[attachment=0:191arvnb] ia0 rps20171119_020528.jpg ia0 [/attachment:191arvnb]
That would be the soft top drain exit, there's one each side. The little flap is there to stop stuff getting in it from the outside but some people remove the flap permanently to encourage a good flow from the drain.
All you need to do is make sure the inlet and outlet are clear and that water flows freely.
If you search for soft top drain you'll find lots of information on it.
edmundopt
Many thanks
I should improve my english:D
No problem my friend, I can't see anything particularly wrong with your English, just inexperience with the subject matter and we all start out that way [emoji2]
Welcome to the club and good luck with your work in progress [emoji1303]
m1tch
Yep, make sure those are clean and clear, they usually fill up with leaves and muck over time, block and then you find your rear bins have turned into a swimming pool!
