Air Filter and Plugs
Started by stavros58, December 7, 2017, 19:09
stavros58
Hi Im looking at booking in for 10,000 service (66,000 on the clock owned since new), local garage are happy if I buy the bits. I've been reading about the K&N 33-2041-1 Replacement Air Filter which has some very good reviews and is a permanent air filter that only need be cleaned approx every 4/5 years, apparently they are great for performance as well. Secondly I'm changing my plugs and usually fit Toyota branded Iridium plugs every 4 years, I've never had an issue with them, excellent start and very good when running so I'm going to stick with these unless anyone has a better alternative to suggest. Cheers   s:) :) s:)
MR2 Chilli Red, final 300 production run for U.K. Hard Top, TTE twin pipes, Alacantra leather. Pre registered, no mods but  Brilliant! Favourite quote "I don\'t expect to know what is around the corner but I do at least expect to know where the corner is"
Get a cheap stock cotton panel filter and replace it every 6 months. It'll take 3 years to recover the cost of a k&n panel...which doesn't filter as well...by which time you really need to replace the k&n anyway. It doesn't stack up
Plugs, copper cheap plugs of the correct spec and replace every year. Same story.
Alternatively a good set of Iridium and change every 2
lamcote
^^ +1
m1tch
JoeCool
The stock panel flows enough air for a 2zz in lift, there's no way it's detrimental to the performance of a 1zz engine. Stick with that!
2ZZ '02 Roadster
Also +1
stavros58
Took everyone's advice and had stock parts fitted copper plugs, standard filter, Toyota oil filter etc that I bought and just paid for labour so £130 in total. I haven't had time to take it for a proper run yet but I'm sure its fine, its always run really well so probably wont see much of a difference anyway. Thanks for responding. Have a nice Xmas
Good call and satisfying knowing it's done.
Nice one. Good to go for another 6 months to a year.
130+parts twice a year to keep the car at its best is a small price to pay  s:) :) s:)
delhusband
D'you ever fancy trying minor service yourself? Understand if you want to keep the service record, but I did my first ever quite recently, and it was really satisfying when finished. I'm a complete novice, so trust me if i can do it i'm pretty sure anyone could  s:) :) s:)  .
And as an example of what £130 will get you, Just a thought, but:
Spark plugs ~ £10
Air filter ~ £10
Oil filter ~ £5
Oil filter sump washer ~ £2
Oil ~£30
Spark plug removal set ~ £22
2 tonne axle stands ~ £20
2 tonne trolley jack ~ £30
=total ~£129 first minor service, then ~ £55 per minor service thereafter +1-3 hours of your time, maybe less
delhusband
Quote from: "delhusband"D'you ever fancy trying minor service yourself? Understand if you want to keep the service record, but I did my first ever quite recently, and it was really satisfying when finished. I'm a complete novice, so trust me if i can do it i'm pretty sure anyone could  s:) :) s:)  .
Spark plugs ~ £10
Air filter ~ £10
Oil filter ~ £5
Oil ~£30
P.s. I did lean on the expertise of the club for assistance when i got a bit, er, stuck  s:D :D s:D
stavros58
Hi years ago I used to do a bit like when I had a Vauxhall Viva, Datsun Sunny and the horrible Morris Marina but to be honest £70 for labour, they have all the tools hydraulic lift etc etc plus I don't have to dispose of the old oil its not really worth the effort or time. I do build all my own computers and have done for 20 years but its clean, indoors pretty easy but still satisfying.  I still do bits I can when possible tbh if I was paying Toyota prices I would do a lot more as their charges are beyond ridiculous.
manos3003
If you can get a bucket from toolstation (less than £5) and a big 5 litre empty water bottle, you can dispose your oil at the local recycling centre for free.
Service on its own is about 30-40 minutes at best. No complicated tools needed or ramps even.
A nice thing to do on a Sunday morning before heading out for a drive  s:) :) s:)
I can't recall a day when I drove my MR2 and it didn't put a smile on my face
<strike>2000 Spectra Blue Mica - 2ZZ-GE gone, but not forgotten</strike>
2002 Spectra Blue Mica K20A2 coming up
m1tch
Or you could use a vacuum oil pump and not need to remove the sump plug, just unscrew the oil filter etc.
