rear lights removal with the duck tail TTE spoiler on?
Started by bigbear007, February 13, 2018, 17:05
bigbear007
Anyone removed the rear lights with the duck tail TTE spoiler on?
As you can see (pic below) it wraps around the light so can it be done ?
I'm changing the left hand lens as it was recently cracked.
Silver 53 Plate SMT, TTE Exhaust, Style Bar, Spoiler, Red Leather, A/C, hardtop.
Quote; "The Bible contains much that is relevant today, like Noah taking 40 days to find a place to park."
StuC may know.
I thought Matt had worked out a way.
Only reason I don't have one is this trouble.
Best spoiler.
Good luck.
I am sure someone (was it @StuC ?) said it could be done by loosening the bumper at the top to give some wiggle room?
The main reason it won't come out is because the light has a peg on the outer side. If you remove the peg it's probably still very secure but you can get the light out (maybe)
bigbear007
Quote from: Topdownman on February 13, 2018, 17:23
That sounds like a plan I'll give it a go when the lens is delivered tomorrow.
The lens from the dealer was only £28 but the gasket was £38.68 !
I have heard that you can use O' ring rubber cord but I'm not sure of the size?
It's cheep enough on Amazon :
https://www.amazon.co.uk/dp/B00N2TK6NM/_encoding=UTF8?coliid=I2YO7EU37P7WB9&colid=1Z1ZD8NQ7AS5C&psc=0
Quote from: 1979scotte
StuC may know.
Nope, Matt worked around it!! Lol.
I was looking to change my rear number plate trim for the FL one. I managed to get enough wiggle room to move the lower portion of the bumper to do the swap.
I never managed to solve the Ducktail Paradox!!! :-(
The only advice to new owners would be to not adhere it to the bumper. It has enough fixings without needing the bonding as well.
Doesn't help current owners though.
One abstract thought has occurred though. Can you loosen the rear quarter enough to change the lamp?
bigbear007
Would I be able to take off the lens without taking the light fully out of place ? :-\
mikek
I've done it. Remove the top bumper fittings and the fittings in the wheel arch. This should give you enough wiggle room. Just! It's very tight. Before I put the lamps back in I cut off the lugs at the side so I had more wiggle room. I then used a small self tapper where the lug was to secure it. Much easier to get out now. Still a pain if I'm honest.
New little car to follow soon
Ex 2zz by Rogue. Se7en cams. BMC CDA. Competion clutches lightened flywheel, Megillian Racing Exhaust. TRD sportivo suspension and ARB\'s. TRD braces. TRD quick shift. TRD dash kit, Matts brace. Getting there but not sure when it will stop!
@mikek perhaps you need to give a paradox masterclass at Ding Day
mikek
bigbear007
Thank's Mikek
I'll be giving that ago tomorrow, I'll let you all know how it went.
I'm going in, I may be a while  ;)
Quote from: mikek on February 13, 2018, 19:24
Actually undoing the two outermost bolts on the spoiler is easier than this and allows you to (just) squeeze the headlight out.
To be honest I now know by feel where the bolts are so it's not that bad.
10 Ratchet spanner in hand and 5 mins and the spoiler is off anyway. It's just a pain in the hoop.
bigbear007
Quote from: shnazzle on February 14, 2018, 00:55
Mine is bonded in as well!  ::)
No time today but I'll give another go next Monday when i'm free
Quote from: bigbear007 on February 14, 2018, 21:22
Bonded in???? Which ape sorted that out?
Why did they think the 6(?) bolts wouldn't hold?
..good luck :)
Quote from: shnazzle on February 14, 2018, 21:52Bonded in???? Which ape sorted that out?
Tell me about it! It's such an unnecessary pain. [emoji853][emoji853][emoji853]
mikek
Mines the same, no way it's coming off the bumper
Genuinely no clue then on how you get access without breaking stuff. I guess you can undo most of the bumper and try to undo bolts as much as possible that way?
mikek
The best bit is you can't take the bumper off without getting the lights out!
