Which brakes for track?
Started by james_ly, June 7, 2018, 18:15
james_ly
Took my new 2 to Snetterton today, only made it until lunch time on the rear pads. Not sure what the previous owner put on but they were good for 3-4 laps only, then faded and disintegrated fast. Do people stick with standard discs and just uprate the pads?
MR2 gone<br />GT86
mikek
Most people use standard discs and yellow stuff pads.
New little car to follow soon
Ex 2zz by Rogue. Se7en cams. BMC CDA. Competion clutches lightened flywheel, Megillian Racing Exhaust. TRD sportivo suspension and ARB\'s. TRD braces. TRD quick shift. TRD dash kit, Matts brace. Getting there but not sure when it will stop!
BahnStormer
and braided hoses / change the brake fluid...
as per @mikek - I've consistently been told that stock disc sizes should be fine for track use and most people use the stock discs.
james_ly
Yep, already done the fluid, pedal feel is fine so I don't think I need the hoses. Also need to investigate the caliper as the left rear wore the pad more. Hopefully just need to grease the slider.
MR2 gone<br />GT86
I would never go on track with unknown pads.
If you find the yellow stuff aren't to your liking there is always carbotech.
james_ly
Quote from: 1979scotte on June 12, 2018, 09:39
Yellow stuff on order, and if they wear too fast I'll try the carbotechs, hopefully won't need to though!
MR2 gone<br />GT86
Kaveney
My Yellow stuff sill look doo and are around 70 - 80 % after I did Barnds hatch last month .
Quote from: james_ly on June 12, 2018, 10:13
james_ly
Yellowstuff seem fine on the road, maybe a bit less modulation, and very first press is worse. But no squeal. Hope they hold up on the track!
MR2 gone<br />GT86
james_ly
Yellowstuff were really good on track, on my road tyres anyway. Feel like they'd cope fine with better tyres as well.
MR2 gone<br />GT86
