Blue injectors in 1ZZ-FED
Started by tom256, September 17, 2018, 09:25
tom256
Hello guys
Did anyone tried newer blue injectors for 1ZZ-FE, and had any performance increase?
More details here:
https://bobistheoilguy.com/forums/ubbthreads.php/topics/3887106/(Green_vs_Blue)_Injectors_for_
I figured out that part number is 23250-22080.
Toyota MR2 Roadster 2005 TF300 Silver Streak Mica
Team Impul NS-GT2 '17
Zero header + Zero cat + TTE Exhaust
TRD Door Stabilizer
Denso TT Iridium
m1tch
Don't think it will make a difference as the stock ECU will adjust the fuel trims to the injectors, just run injector cleaner through it and clean the MAF etc.
tom256
Quote from: m1tch on September 17, 2018, 15:03
Looks like these are new generation if injectors Denso UC (hole taperet) .
These should provide some minimal benefit in MPG, and engine should be more responisve.
http://densoautoparts.com/fuel-injectors.aspx
https://www.youtube.com/watch?v=18ON0aI-D4k
I already have one set and will assembly it in March probably.
TRD Door Stabilizer
Denso TT Iridium
I'm pretty sure the stock 1zz injectors are already 12-hole.
So I can't imagine they would offer any benefit at all.
As said above, if they deliver more fuel then the ecu will just reduce the duty cycle based on the o2 readings. So you end up with the same output.
If new ones are cheaper than getting your stock injectors cleaned (75ish) then it will be beneficial in the fact that they're cleaner. Otherwise, seems like a waste of effort. Run a few bottles of injector cleaner through and run good fuel like vpower with cleansing agents in. Sorted.
tom256
Quote from: shnazzle on January 10, 2019, 11:08
Yes, old injectors are 12 holes. It's all about droplet size.
I bought blue ones refubrished, so it was cheap.
TRD Door Stabilizer
Denso TT Iridium
All a moot point as you've got them! Haha.
Upside is, it can only lead to good things putting fresher injectors in. Even if they were exactly the same.
Do they have a different spray pattern than stock?
Only that and perhaps dwell time could make a difference
tom256
Quote from: shnazzle on January 10, 2019, 12:27
Check first post for diffrence. There are photos. There is a diffrence in holes placement.
Fuel spray should ignite better. So I expect engine to run more smoothly.
Maybe reaction of engine will be a little better.
I will post some photos on March when I will replace injectors.
TRD Door Stabilizer
Denso TT Iridium
tom256
Quote from: tom256 on January 11, 2019, 17:27
So I installed new injectors and looks like one is faulty (P0302 code) :/   Chineese quality :/
Anyway photos below for comparision. Take a look at nozzle placement.
Blue left, green right.
https://imgur.com/a/qFoW8zO
https://imgur.com/a/eKrqrDK
Tommorow I will switch back to green ones, and I need to wait for RMA and I hope 'new' injector.
TRD Door Stabilizer
Denso TT Iridium
tom256
So finally I installed blue injectors.
Engine looks like running more smoothly on idle.
I didn't notice any power increase as expected, but also I didn't notice any better throttle response and this was disappointing. Maybe driving car with stable speed 140km/h on highway was not best test.
Mpg still to be checked.
TRD Door Stabilizer
Denso TT Iridium
