Screwed o2 sensors?
Started by Wrightly, April 5, 2005, 14:23
Wrightly
Hi,
I own a jap imported 2000 MRS.
I recently had to have the engine reconditioned and cat replaced after having a heavy right foot.
Since I have had the engine recon and cat replacement - due to a huge amount of carbon flowing through when I blew the engine - it still is not running properly.
I have done 3,000 miles since and can feel the engine running in.
The problem is that it is: drinking fuel, has poor performance, faltering start in the damp (occasionally),  the check engine light will come on if I'm going up a hill, and if I try to redline it, the engine splutters and the engine light flashes with the splutters just before the line.
I have been told that it is the o2 sensors. I understand that Gendan do a cheap (£32 instead of Mr T's £150)! 4 wire Zircona job, but would it be ok to put these in my car?
I'm planning on ordering three and replacing the lot.
Have any of you guys bought these and have you had any problems? I don't want to fork out more cash to find out they don't work.
Cheers.
so.simple
For what I know (someone please correct me), the ones sold by gendan are the same you would get from Mr. T: made by Denso. The only difference is the fact that you will have to re-use the wires from your current sensors.
Carlos
Yep, the Gendan replacements are fine and you will have to reuse the existing wiring harness. The engine light flickering is usually to indicate detonation.
Wrightly
Thanks guys,
The new ones have now been ordered so will hopefully be back up and running in no time.
Quote from: "Slacey"The engine light flickering is usually to indicate detonation.
I thought only the PFC had that feature...?
(or maybe he has one, kinda sounds like it though)
Wrightly
Tem,
What is a PFC? and when you say 'detonation', what's that all about?
Sorry if i'm ignorant. I'm not very technically minded on engines.
Quote from: "Wrightly"Tem,
I think the PFC that Tem's referring to is an ECU piggy-back device, made by Apexi, for controlling fueling, etc, and ultimately increasing performance. see here!
IIRC detonation (also known as pre-ignition) is where fuel combusts in the cylinder before the spark ignites it - during the compression stroke of the engine. Obviously this can be v. bad as it can lead to bent con rods and mullered big ends...  s:scared: :scared: s:scared:
PFC isn't a piggy back it's a complete ECU replacement, just for the record.
Quote from: "mr-s_turbo"PFC isn't a piggy back it's a complete ECU replacement, just for the record.
Yep!  s8) 8) s8)
And the reason I mentioned it was, that it blinks the CEL with some issues (like knock), but I've never heard that the stock ECU would do that and the Owner's manual didn't mention anything about it either. And since you have a jap import (used?), maybe you actually have a PFC instead of the stock ECU?
Wow! I stand correted...   s:wink: :wink: s:wink:
Quote from: "Mr 2"
I think you'll find that's corrected   s:P :P s:P    s:lol: :lol: s:lol:
 s:lol: :lol: s:lol:    s:lol: :lol: s:lol:    s:lol: :lol: s:lol:
No, I meant correted!   s:oops: :oops: s:oops:
Maybe I should get a "dialing wand" - my fingers must be too fat!   s:lol: :lol: s:lol:
