Results of 40K service. Any ideas?
Started by Anonymous, April 5, 2005, 16:58
Ok guys. Just got the car back from Coldhams Lane Toyota in Cambridge. Always been pretty good and good service.
Cost was £261 all in, with a replaced wiper blade and a rear sidelight bulb. Thats the good stuff.
The bad stuff is that apparantly the handbrake cable is sticking on on the nearside (which needs "further investigation"), the inner surface of the front discs are corroding (recommended replacing discs and pads at an incredible £302!!!!!) and more worryingly, there is apprarantly a coolant AND oil leak from the off side of the engine somewhere, which again, they said requires further investigation. The woman rang the service department to talk tot he guy who did my car to find out the "extent" of this problem and the work it might entail to "invastigate" this. She spoke to him in front of me and apparantly the engine has to be removed frmo one of its mounts and lowered a little so they can get a whole loads of mirrors and stuff in there to have a look and she reckoned that it MIGHT need a couple of days in there to properly find out whats wrong and repair of needs be!!!
Firstly, I am not worried about the discs. They were replaced under warranty about 2 months after I got the car, so have only been on the car about two years. Will just get pads replaced.
But the leaking is a worrying thing. I have posted other threads on here about the coolant loss I have experienced before and I did have an almost disasterously low coolant level one day where the header tank was completely empty and the engine overheated a little. But I topped up the coolant and its been over the full mark ever since and not dropped. The oil levels have never dropped either and there is no "scum" anywhere to suggest a head gasket is gone............but I CAN see where they are talking about. The block is "stained" on the top right, under the head, to the right edge as you look at it, but I can't pinpoint where the leak itself is coming from oe what it actually is (i.e.oil or water or both).
So, firstly, does anyone have any idea what this could be? Secondly, if they take the car in for "investigation", do they charge for looking at it (I was in a bit of despair and a rush so forgot to ask)? Cos if they do, a couple of days is going to absolutely cripple me!!! I can't afford that, especially as I have booked track time and its paid for and I also need the brakes done (which are pretty important on a track!).
Is this going to be seriously big? Any clues anyone?
Hope you can help cos I am a bit worried about this now..................  s:scared: :scared: s:scared:  Ijust hope it really ISN'T the head gasket. Thats the LAST thing I need.................and why would it go if it is anyway? Its not as if I drove the thing like I stole it everywhere. Its serviced, looked after like a baby and most of the driving is moderate A road and motorway driving. Other than the pre-cats coming out, I have NEVER touched the engine. Completely stock.
Mystery to me and a scary one at that...........HELP!!!!!!   s:cry: :cry: s:cry:
Comer
John
Is there anyway that the coolant you topped up with may have overflowed from the expansion tank and made a mess that way?  Clutching at straws I know but I hope it ends up being as simple as that.
Michael
Now:  Black 2002 Rav4 Cruiser
As for the oil on the right side of the head, mine is the same - if you look at the pics I posted of the turbo install you can clearly see it on the engine shots and most cars seem to do it - nothing to worry about though. Coolant on the other hand is a different matter  s:? :? s:?
I would wash it off and drive it for a bit to see how much or if any leaks
reacure, brake cleaner or carb cleaner is the best, just spray it on and it will almost bring the head and the block up like new, and then you will soon see if there is a problem.
As for the brakes, my disc's had corrieded on the inside and did need changeing as it would not pass its MOT as they were, it is very easy to do
your self and the cost for front disc's and pads were around £150.00 mark
from TOYOTA.
As for the hand brake im sure a good dose of WD40 up the cable will do
the trick.
I some time think nowadays with serviceing be 10,000 mile or 12month
before the car see an oil can it dose lead to problems such as lack of
lub on cable and door hinges and so on
Good luck
darrenjuggins
Hi John,
I had the brake cable problem on my last MOT, cost about £120 (paid by extended warranty). Not sure why it happened, but was classed as an MOT faliure - doh !
As for the coolant loss and the investigation time - unfortunately investigations are on the clock and will be charged the same as if they where fixing something.
The coolant level can change dramatically after a long journey, or after a really long hot drive, but unless you have visited the desert recently, I can't account for the loss in the current weather conditions.
Hope you get it sorted John, sorry I can't be more help.
Darren
Darren A. Juggins
oil leak on teh right hand side of teh block just below the cam cover is likely coming from the plate that secures the chain tensioner
it's a common, (every engine I've ever seen) occurence, mine has stopped since I went to a thicker weight oil.
mmm...interesting stuff. I didn't realise the "staining" was such a common thing and by the sounds of it, nothing too much to worry about either. I think I will try Maxum's idea and give it a spray (I have some carb cleaner somewhere........) and then see what comes out, if anything. Will also keep an eye on the coolant from now on too. I don't like what Darren says!!! Checking things on the timer......if they have to have it in for a couple of days, I am screwed!!!! Glad there are a couple of people on here who I know to be knowledgeable people on these things who also have the staining too. Makes me feel a little better.......
I think I might give the brake cable a spray with the old WD40. Is it easy to get to? I don't have a garage, a jack (other than the one supplied with the car) or ramps.
My bit problem with this all is that its MOT is up at the end of April, and I am tracking in at Rockingham on May 2nd, so I want all of these things sorted before then, but can't really afford too much. I could do without a MOT failure AND having to replace all of these things.......
Blimey, it all comes at once doesn't it. Wish me luck!!! Cheers for the help!
use penetrating oil, not wd40
Quote from: "markiii"use penetrating oil, not wd40
Got some of that too. Are the cables easy access? Would it be easy to be able to get to them enough to be able to spray the stuff into them?
Sorry for the questions, but I don't have facilities to do this stuff and have never been actually under my car. Its not that I am mechanically minded (i'm actually not bad when I get going), but with this car, its all still pretty new cos I have never had to work on it myself........
Ok, update.
Phoned MrT to see if they could book me in to change just the brake pads on front and rear. They took details of the car and recognised that it was in yesterday and they advised of the corroded discs.
But they refused to change jst the pads for me!!! They won't do it without changing the discs too cos they said it would "compromise braking efficiency". I just can't afford the best part of £320 right now! Not after its big service.
So, looks like I might have to have a go myself sometime.
Does anyone recommend discs OTHER than the standard MrT ones that maybe cheaper than stock? Or does anyone know where I can get equivalent discs from? Or do you reckon I can get away with trying to just change the pads myself and is it easy? Can anyone put me in the direction of a "guide" on how to do this? Would make life a LOT easier and cheaper for me right now. I am just worried that when I go to Rockingham, I am going to cause damage or something.
I think that there is still a reasonable amount of meat left on the pads though, so I was wondering if I should just leave them and take it to Rockingham anyway and just use up what is left on them and get them changed AFTER I get back from there?
Sorry for all the questions guys, but I am in a BIG dilemma about all of this right now............  s:? :? s:?
Quote from: "John Woodward"So, looks like I might have to have a go myself sometime.
It's really quite simple. Basically just remove the wheel, open the lower bolt of the brake caliper, swing it up and replace the pads.
IIRC, the front brake pistons can be pushed inwards, but the rear ones have to be screwed back in...
And if you have filled the reservoir with brake flluid with worn pads, take some off before pushing the pistons in or you will have it all over the place (and it eats paint).
QuoteDoes anyone recommend discs OTHER than the standard MrT ones that maybe cheaper than stock?
Check eBay for cheaper discs. And get some zinc plated while you're at it. They probably won't make a difference in braking either way...
The stock ones are a good choice though, if you decide to replace them. Have you measured their thickness?
Quote from: "Tem"
Can't say I have checked the thickness of the discs, but I reckon there must be LOADS on them as they were only replaced 2 years ago and I rarely brake hard as most of my driving is on A roads or motorways. They were replaced under warranty about 2 months after I bought the car.
Will check eBay, but might just go for the stock discs in the end and have a go at changing the pads myself one weekend. Hopefully the weather will get a little better........
Cheers for the advice Tem!
The Spyder's braking ability is a legend in our own time. I'd stick with OEM parts and put the effort into finding a good deal on them. Remember that your dealer can always knock something up to 25% off the cost of any part (and labor, too) and often will if you ask politely. Tell 'em, "Hey, I bring the car here for service and I've recommended you to all my friends and family, so can you please cut me a bit of a break here?" or something similar.
A few owners at SC have spent quite a bit extra to upgrade their braking systems with racing parts, etc., but no one that I'm aware of has reported that the additional cost was worth it.
Quote from: "John Woodward"I don't like what Darren says!!! Checking things on the timer......if they have to have it in for a couple of days, I am screwed!!!!
Yep, imagine, you'll have your car there for 3 days and: "Well, there seems to be some leaking, but we feel it's nothing serious, actually quite common in these engines. Keep an eye on it and come back if it gets serious. That'll be 967£ please."  s:shock: :shock: s:shock:
I've learned already a long time ago that mostly when there is something wrong with me/my car I have to determine what the problem is myself, and then just tell the doctor/garage what to fix. The reason for it is quite simple, you are the only one who is REALLY interested in you/your car, for anyone else it's just a job they want to get rid of.
As to engine coolant, oil leaking and brake problems, I think they are "standard" Toyota features. The brakes need to be fixed of course, but for the coolant and the oil, I would really just keep an eye on it and live with it. (We've had in total 7 Camrys, 3 LandCruisers, 1 Previa, and 1 MR2 in our family -been there, done that)
EDIT: typo
Ok, another update........
Got the car up last night and had a look to where the handbrake cable was. I sprayed everything I could see that was connected to the cable with penetrating oil and its made no difference. When the car was up, the handbrake was on, yet the left rear wheel was free wheeling easily. Its as though the cable is actually stuck so it won't go on.
How do I actually get inside the cable to spray it? And, am I correct in thinking that if the cable won't move when I pull the handbrake on, I might have stretched the cable and therefor the cable is scrap anyway? Will I need to change this regardless? Or does it self adjust if I can loosen it?
I couldn't actually see how I could get into the cable to spray it to be honest.
Any ideas anyone?
If it was stuck ON, then I might have an easier time I reckon. As its stuck off.............well...........anyones guess really.........
Problem is, the MOT is in 2 weeks too!!!! DOH!!!!
Any ideas for how much a cable and fitting would be?
If the cable is similar than on Mk1 MR2, then you can't do much more than replace it...
Does the brake work normally (with the pedal that is)?
The rears freeze if you don't use them and a good braking might unlock them. That's pretty common with Mk1 after winter, when you basically don't use the rear brakes at all. The corroding on the other side might suggest that things aren't moving properly even with normal brakes...
Johnny, fyi, last year I needed my brake pads/discs replacing to pass my MOT, and like you got quoted horror money by Toyota, went to Formula 1, and they done it for 200 smackers, they had to order in the parts especially as the they were quite scarce last year it seemed.
Quote from: "Tem"If the cable is similar than on Mk1 MR2, then you can't do much more than replace it...
I think the cable and mechanism is VERY similar to that of the Mk1 to be honest. I have worked on both of my Mk1's and had problems with sticking cables and calipers with that, as you described too. hey seems much easier to work on though........
The brakes work fine with the foot pedal. It just seems that the handbrake is stuck. Going to have to have another look this weekend I reckon.........
As for the corrosion, MrT said that it was only on the front discs, which is weird, so I don't think that the handbrake has anything to do with that!!! I hope!!!  s:shock: :shock: s:shock:    s:wink: :wink: s:wink:    s:lol: :lol: s:lol:
Will check them out and keep you posted, but looks like I might have to get them replaced. So far, the only figure anyone has been able to come up with is around £120!!! For a bloody handbrake cable and fitting!!! Sheesh...........  s:shock: :shock: s:shock:    s:roll: :roll: s:roll:
Quote from: "Stevo"Johnny, fyi, last year I needed my brake pads/discs replacing to pass my MOT, and like you got quoted horror money by Toyota, went to Formula 1, and they done it for 200 smackers, they had to order in the parts especially as the they were quite scarce last year it seemed.
Where is this Formula 1 Stevo? They might be worth checking out. I think I am going to leave the changing of discs and pads until the MOT though and see if they spot it and if they do, see if they say it is detrimental to anything. I trust the people who do the MOT a lot, yet I don't trust MrT all that much cos they will report the slightest little thing and then make it out as though its almost bloody life threatening........Will be interesting to see what comes of that. But the handbrake is an obvious MOT failure, so I need that to be done as priority I reckon.........
Here you go John - similar to Kwik Fit et al
 m http://www.f1autocentres.co.uk/ m
Cheers Sean. Top stuff. Never heard of them before. Will look into it to see if there is a local.............
