Traction control
Started by Zxrob, September 29, 2019, 20:00
Zxrob
Forgive me if this sounds a bit naive but not had the car long so just getting use to it
My owners manual points to a TC button by the steering wheel, in my car there is just a blank pate,its a 2004 model, is this right
Cheers Rob
Adventure before dementia 😁
I may be wrong, but I believe this was only fitted to the SMT model.
I believe that is correct. (so we might both be wrong)
m1tch
If you have a Link Xtreme you can fit traction control if needed, will be doing it on mine at some point.
Quote from: Alex Knight on September 29, 2019, 21:13I may be wrong, but I believe this was only fitted to the SMT model.
Optional. As was cruise control.
The SMT already has speed sensors and fly by wire throttle body.
Gaz2405
Quote from: m1tch on September 30, 2019, 07:00If you have a Link Xtreme you can fit traction control if needed, will be doing it on mine at some point.
Oooh I wonder if my Apexi Power Fc can do that...... 😂 NOPE!
m1tch
Quote from: Gaz2405 on September 30, 2019, 10:28
Its one of the reasons I upgraded further from the Power FC to my Link unit - plus the additional launch control/anti lag as well as traction control and knock protection.
Chilli Girl
Sadly, I ain't got a clue what you're all talking about. Best I stop reading this post. Sorry guys, way over my head.
Zxrob
Quote from: Petrus on September 30, 2019, 09:48
So, TC was optional only, that eplains why my rear was moving around on a greasy island Saturday at pretty low speed
Cheers Rob
Quote from: Zxrob on September 30, 2019, 14:29
Cheers Rob
All weather tyres with plenty of meat?  That is usually sufficient to avoid roundabout slides.
Zxrob
Quote from: Carolyn on September 30, 2019, 14:44
Cheers Rob
Also need to re-calibrate to "old school" driving ;D
Rob
m1tch
Cheers Rob
Our cars don't need TC, if the tyres are decent and at the correct pressures they have loads of grip, only looking to run traction control in mine as I am planning to be running triple stock power levels.
Quote from: m1tch on October  1, 2019, 07:44Our cars don't need TC, if the tyres are decent and at the correct pressures they have loads of grip,
Furthermore, being able to play with the traction is part of the charm of rwd no?!
I had mine on El Cheapo no-grip rubber for the first few months (over the winter) on purpose so I could learn the car´s behavior at lóóóów levels of grip = lower levels of speed.
Been ´caught out´ only once and that was trying the handbrake action during roundabout drifting angle limits discovery :-)
Cheers Rob
Either your tyres are pony your pressures are low or you're driving to fast for conditions.
I have no traction issues and my car is heavier and more torquey than most.
TC not to be confused with Electronic Stability Protection/System/etc.
The former is your right and left foot (on clutch), the latter is not possible on our cars unless you implement some new braking system.
