Clutch upgrade
Started by BenF, April 9, 2005, 23:40
BenF
Ok, I could do with some advice ... I'm looking to fit a PE turbo to a roadster - and rather than fit the turbo and then find the standard clutch can't handle the extra torque, it make sense to change the clutch whilst fitting the turbo(!)
Seaching back through posts here, the clutches that seem to get a mention are the TRD and RPS cluches from the USA.
Any views on which one is better?
I've just decided that browsing the  Japanparts website is a very dangerous thing to do ....
I get  what your saying, but fitting the turbo is nothing like or close to fitting a clutch.Their basically 2 seperate jobs and your going to have to complete 1job before you start the other anyway, so i say do the turbo and see if the stock holds out for a while, mine has.
There are a few choices out there for replacement but there's not many to get a comparison of which is better.
Strangely, after taking you out Ben and my stock clutch slipped, it then got quite bad, but at the last meet I took a number of people out and didn't exactly hold back and it didn't really slip once - it seems fine since as well  s:? :? s:?
I think the best way to go would to be as I (and Ian) have done - get the parts in, but fit and run the turbo first as the stock one may last a while - I think mine may have been glazed which caused it to slip, and pushing on it a bit has cleaned the surface off again.
BenF
Hmm, interesting - so perhaps its best if I wait until the clutch is definitely on the way out before replacing it.
I guess what I was thinking was that if the car is going to have the Turbo kit fitted at Millway (probably with me leaving it there for a week) it might make sense to swap the clutch over whilst they've got the car. I'm considering taking it over to the Nurburgring once it is done this summer, and I'd rather not get there and find the clutch is slipping (!)
But if I hang onto the standard clutch - what find of torque/ power levels has people found that it able to handle from a turbo'd car? I guess I'm hoping for 200-225 flywheel bhp and 180-200 ft/lbs of torque from the PE turbo kit.
BenF
Quote from: "Slacey"Strangely, after taking you out Ben and my stock clutch slipped, it then got quite bad, but at the last meet I took a number of people out and didn't exactly hold back and it didn't really slip once - it seems fine since as well  s:? :? s:?
Yeah, thanks for the ride in yours Sean - it certainly confirmed that a Tubo kit was the way forwards   s:twisted: :twisted: s:twisted:  and yours sounds really good!
But your turbo installation is always on best behaviour when you're giving people passenger rides  s;) ;) s;)
QuoteI think the best way to go would to be as I (and Ian) have done - get the parts in, but fit and run the turbo first as the stock one may last a while - I think mine may have been glazed which caused it to slip, and pushing on it a bit has cleaned the surface off again.
I may well do this - I'll give the folks at PPE a ring and see what the current pricing is, and work back to the price in the UK after import duty etc is paid.
I've found that  w www.japanparts.com w  list the TRD sports clutch and pressure plate for £230, which seems quite a good price ..
Well if your getting rid of your cat, having an IC and i'll assume your having a larger diameter exhaust, then you won't need more than 6.5psi to get your goal flywheel bhp. I can boost at 9psi with no clutch slip, more than that it doesn't hold. It did for a while hold at 12psi but no more.
BUT that's 1 in a string of others that have failed as soon as the car see's any boost, so it's your choice, in the end you will need a clutch so if it's easier for you to do it while it's in the garage then i say do it.
BenF
QuoteWell if your getting rid of your cat, having an IC and i'll assume your having a larger diameter exhaust, then you won't need more than 6.5psi to get your goal flywheel bhp. I can boost at 9psi with no clutch slip, more than that it doesn't hold. It did for a while hold at 12psi but no more.
Hmm, decisions decisions. The clutch *will* go, its a question of replacing it now or later I guess.
Sounds like you've got quite a setup with your car though! Do you have any dyno plots available showing the different power / torque levels you've achieved at different boost levels?
No i never bothered with a dyno. I always intended but never have, i just know it's freaking fast  s:twisted: :twisted: s:twisted:
