Offer from Mr T - Engine Flush and Fuel Flush?
Started by Liz, April 17, 2005, 20:38
Liz
Booked mine in for its 50k service the other day, its going to be done on the 30th.
I was offered by the nice lady on reception an Engine Flush and a Fuel flush for £19.99 on top of the normal service price.
Apparently this engine flush - totally removes all cr@p out of the engine itself before they refill it with oil ....I was ok at that point and considering it, but then it came to the fuel flush...she mentioned that they would put something into the tank and it would clean the system through, and this substance stays in the tank?????  I said no at this point.
Has anyone else been offered this, would it affect the unichip (on the fuel side of things)...I want the car to have the best but not if it sods up £500 worth of chip and tuning?  I did mention the unichip, but could hear the whoosh down the phone as it went over her head completely  s:roll: :roll: s:roll:  .
darrenjuggins
Hi Liz,
The Forte Engine and fuel flush, used to be a common "add on" to a service, it's basically a degreser they run through prior to putting the oil back in and obviously for the fuel it's helps reduce the moisture content.
£19.99 sounds about right for the product, as you can buy it off the shelf.
But - I looked at my engine when it was removed from the car and I've got to say it was as clean as a whistle, no deposits on the values or piston heads.  Therefore, you could be paying for well - nothing really !
I'm sure if you drive at a how shall we put it "brisk" pace from ime to time, you will keep any deposits down to a minimum.
Your choice, it certainly won't do it any harm, then again if my engine was anything to go by it might just be money down the drain.
Hope this helps
Darren
Darren A. Juggins
Had them both done on my 20k service and I don't seem to have any problems at nearly 30k now
By the way if you do manage to decypher this bill I'm impressed.
Quote from: "Les"Had them both done on my 20k service and I don't seem to have any problems at nearly 30k now
but are you running the unichip Les?
Liz, I'd go for both of the offers. You've mentioned that you do a lot of short trips, so this would fall under "good and required maintenance." Radiator and brakeline and clutchline flushes are also worthwhile at 12 to 36 months intervals, depending on driving style. The liquids degrade and get corrupted with the introduction of H2O, so these services keep everything happy and the price sounds utterly reasonable.
My dad has his own garage and I add the Forte fuel flush about every six months.
Another question. I had my 2 year service the other week and have been rang up by the dealer saying my brake etc fluids should have been changed at extra cost. Do I bother at 2 years and 16K miles  s:?: :?: s:?:
Liz
My main worry was the unichip and the stuff that they put in the fuel...as the engine has been tuned to running on 97RON, would this stuff affect it?
Quote from: "Liz"My main worry was the unichip and the stuff that they put in the fuel...as the engine has been tuned to running on 97RON, would this stuff affect it?
It shouldn't affect the octane rating at all Liz, so I shouldn't worry.
Liz
For £19.99 I will book it up, the worries about the octane now gone - thanks guys!
Quote from: "kanujunkie"
Sure are!  s:wink: :wink: s:wink:
Quote from: "Les"
bloody marvelous isn't it  s:wink: :wink: s:wink:
