shoot me down or flame me but pls help
Started by Ac1962, January 5, 2021, 13:04
Ac1962
OK, i know this sounds like a noob question or infers ive not scoured the forum for answer but i must have blind goggles on or something, i cant find the answer....please dont laugh , or do, i know you will but, how do i change a headlight bulb? what do i need to remove for access. i know its probably a 2 min job and patently obvious but im having real brain fog issues right now.
Is it a facelift (2003-) or pre facelift model (- 2003)?
If you are unsure; does it have fog lights or not.
In neither case it is 2 minutes as you need to take the vanity plastic out.
Hammond
05' silver
Ac1962
We don't do 'shooting down' or 'flaming' in this club.
No  such thing as a stupid question here, either. :)  8)
@Ac1962
Via "search " I found a similar question that was asked a  while ago with various responses, you will see that
@2 of the left provided some definitive answers.
I have read elsewhere that it is challenging, and also worth a £5 in entertainment to get Halfords to do it.
https://www.mr2roc.org/forum/index.php?topic=42271.0
Use a small mirror to see how the spring clip engages.  They can be sore on the thumbs. The MR2 isn't too bad, I've had worse.
My usual response is along the lines of;
You need a bulb, patience, a flashlight, alcohol to drink, alcohol to disinfect wounds, drugs to numb your soul, drugs to ease pain. But mostly patience and/or luck.
Front plastics out, undo wire clip to appropriate bulb, remove the rubber cap, undo the clip, remove bulb and adapter. Remove adapter from old bulb and place on new bulb.
Put new bulb in place. So far you should be about 10 mins in.
Spend next 45 mins trying to get the clip back on by feeling.
After this time you will be glad for the alcohol and drugs.
Mr2paul
Exactly that👍 And fingers made of smoke 😄
Learning is good. Failing to learn is not an option
Quote from: Carolyn on January  5, 2021, 14:36We don't do 'shooting down' or 'flaming' in this club.
Just good natured ribbing with those we know can take it 👍🏻
paulj
Sometimes they go easily, other times @shnazzle has the description perfect!
As an alternative pay Halfords to fit them - the entertainment of watching them do it might be worth the cost........
Today
In the late 1980's
Oh and take care when fitting the new bulb in:
Because the angle is a bit awkward you cán angle the thing a bit too much and drop it in the lamp unit. Í did  :-[
Not a nice feeling when that happens.
Had to fish it out using a wire with a bent tip.
Nice feeling when thát happens  ;)
I put in higher wattage; is brighter.
To reduce the heat a bit, left off the rubber covers; is lighter   :))
Quote from: Call the midlife! on January  5, 2021, 16:53
Yeah right
jonbill
If you take the front bumper off it's easy. Once you decide to do it, taking the bumper off isn't hard either.
Quote from: jonbill on January  5, 2021, 20:31If you take the front bumper off it's easy. Once you decide to do it, taking the bumper off isn't hard either.
But then sometimes the clip goes straight in :)
I remember years ago I posted on here that I was back in the house with bulb fitted 10 mins after I started.
Do you risk it? :)
Quote from: shnazzle on January  5, 2021, 21:50
Do you risk it? :)
Nobody believed you.
Quote from: 1979scotte on January  5, 2021, 22:12
Do you risk it? :)
It was remarkably quiet afterwards....
Quote from: shnazzle on January  5, 2021, 16:24My usual response is along the lines of;
Post of the day. Took me right back.
I'm trying to visualise if you could go in through the wheel arch if you dropped the liner? I'm more familiar with the rear end than the front 😆
Quote from: Call the midlife! on January  5, 2021, 22:55I'm trying to visualise if you could go in through the wheel arch if you dropped the liner? I'm more familiar with the rear end than the front 😆
Teehee
I'm going to have to siit and look through my photos tomorrow when I should be doing some work...
I always like coming at things from the tradesmans entrance
Bossworld
Quote from: Call the midlife! on January  5, 2021, 23:08I'm going to have to siit and look through my photos tomorrow when I should be doing some work...
It's nearly Easter, don't start today, what you can put off until tomorrow.
ptennisnet
Main bulbs are as above depending on how lucky you are that day.  For me, it's the sidelight bulbs that are the worst (on a PFL).  A bumper off job that gets left until just before MOT time.
scm2004red
Quote from: ptennisnet on January  7, 2021, 14:56Main bulbs are as above depending on how lucky you are that day.  For me, it's the sidelight bulbs that are the worst (on a PFL).  A bumper off job that gets left until just before MOT time.
That's not what I want to hear after the MOT man suggested my sidelights were a bit dim doing the MOT last month "a sign the bulbs are about to go" thought it would be simple...
MR2 Red Edition 2004
Porsche 924 1984
