Tacho pulse wire?
Started by kanujunkie, May 19, 2005, 14:53
anyone know the colour/location?
cheers in advance  s:D :D s:D
dont worry i've found it, it's a white wire behind the instrument cluster i think, can someone confirm that i'm right now?
http://www.tandridgecanoe.co.uk/roadster/041cm.pdf
so.simple
I can confirm it, but only later... I'll check on the instructions that came with the Cruise Control Kit.
Carlos
cheers Carlos, much appreciated
Quote from: "kanujunkie"http://www.tandridgecanoe.co.uk/roadster/041cm.pdf
Stu, I knew you would make use of that CD sometime   s:wink: :wink: s:wink:
I think the TACH signal to the instrument cluster is plain old analog, by the way.  I was going to use that as an input to a "window switch" (RPM-activated switch).  I haven't checked the signal... that's just what Blitzo on Spyderchat told me.  He would know.  If you want a pulse, it's going to be elsewhere.
so.simple
According to the Cruise Control manual, the TACH signal can be found on the white wire on connector IC2, Pin 7...
See the scheme right before the last picture:
http://www.monkeywrenchracing.com/images/cruisepicsummary.jpg
Hope this helps.   s:) :) s:)
Carlos
Quote from: "Beanie"I think the TACH signal to the instrument cluster is plain old analog, by the way.  I was going to use that as an input to a "window switch" (RPM-activated switch).  I haven't checked the signal... that's just what Blitzo on Spyderchat told me.  He would know.  If you want a pulse, it's going to be elsewhere.
Bugger if it is, the shift lights i have work off a digital input only!
Quote from: "so.simple"According to the Cruise Control manual, the TACH signal can be found on the white wire on connector IC2, Pin 7...
Cheers Carlos  s:D :D s:D
Sorry about that... that's just what I was told.   s:) :) s:)
no offence, cos i've got a orrible feeling your right, but i hope you're wrong  s:wink: :wink: s:wink:
so.simple
I, on the other hand, am 95% sure it is digital. At least that's what the MWR cruise control manual says...
Carlos
aaaahhh cr*p, oh well i guess i'll just give it a go then, thanx guys, i'll let you know how i get on  s:? :? s:?
well, it is a digital signal  s:D :D s:D  much to my releif, and i now have a set of fully functional shift lights, only problem now is that in fitting the unit 3 bulbs have blown in the dash and one fell out and i cant find it!
anyone got a p/n for the bulbs?
Surely you mean filaments Stu   s:lol: :lol: s:lol:
sorry mate, wont happen again, FILAMENTS then  s:roll: :roll: s:roll:
Well, that is good to know (pulsed signal).  I thought that it was before Blitzo told me it was analog.  Sorry for making you sweat it.   s:oops: :oops: s:oops:
no probs, but you wont know how releived i was when it burst into life, the revlight is a neat little unit as well, quite descreat
Quote from: "kanujunkie"only problem now is that in fitting the unit 3 bulbs have blown in the dash and one fell out and i cant find it!
Butterfingers!  s;) ;) s;)
Pics!
And sorry, no idea on the p/n for the bulbs..
so.simple
I already it's made of rubber but... Is it green? It looks green in the photo. Do you know if it can be bought online? I'd be interested in getting one.
Carlos
Quote from: "so.simple"I already it's made of rubber but... Is it green? It looks green in the photo. Do you know if it can be bought online? I'd be interested in getting one.
yes and no to the green colour, its actually see thru rubber and the green part is the PCB inside, wierd thing is the pcb is rubbery as well and bends. Unit comes with 2 stickers to go on top of it to cover it up if you want. I'll find some places that sell it, i got mine from a motorbike shop as thats what its designed for
Thanks for the eBay link  s:wink: :wink: s:wink:
so.simple
Quote from: "Slacey"Thanks for the eBay link  s:wink: :wink: s:wink:
Why? Oh God, why?!?
Carlos
