Aftermarket seats
Started by Anonymous, June 15, 2005, 17:21
Has anyone in here fitted aftermarket seats in their 2?
I have just bought some and Im trying to work out how to fit them to the old frame!
can anyone help me with this please?
might help if we new what seats?
Adam did this didn't he  s:?: :?: s:?:  (Jap 300)
Quote from: "heathstimpson"Adam did this didn't he  s:?: :?: s:?:  (Jap 300)
Adam did try with some Rage seats that I bought of him.  Although they fitted physically in the car the driver couldn't.
Jap GT300
I think it turned out in the end that the seats were ideal for someone very small.
Because the roadsters seats have the sliding mechanism built into the side sponge they sit very low.  I think most aftermarket seats are going to be too tall.
The rage seats that I sold had the roadster mounts custom fitted to the aftermarket seats.  There was lots of grinding, driling and welding, it was about 4hs work for a proffesional.
Have just done this on the GT Four.  As with the 'two' the seat frames are very low so any aftermarket frame will have your head bouncing off the roof!   s:lol: :lol: s:lol:
what you need to do is seperate the two halves of the stock runners, they run on bearings between the top and bottom halves, so you need to dig these out with a screw driver and then lever away any bits that stop you sliding the two parts apart.
once apart you will be left with two seperate sides for fixing back to the floor with nothing in between.  I personally bolted two wooden struts across these whilst in situ to hold them square and in their normal positons, and then took them down to the local wleder to have 2" steel bar welded accross front and back in line with the fixing point on your new seats (cost £20 inc scrap steel bar)
once back home you can drill the steel bar where the seat fixing points are and voila you have after market seats at near enough stock height.  The seats I chose came with their own runners, so I still have the sliding option, but i've ripped out the back seats anyway so wasnt really a requirement.
Quote from: "perry190"Have just done this on the GT Four.  As with the 'two' the seat frames are very low so any aftermarket frame will have your head bouncing off the roof!   s:lol: :lol: s:lol:
When are you going to show us some pics of this new project Perry  s:?: :?: s:?:
Bodywork
Customised veilside bumper
PIAA spots
Customised  Varis side skirts
Custom rear skirt (calibra)
Custom roof vent
Hero rear wing
Varis roof spoiler
Customised VIS front wings
Custom mirrors/ integral indicators
Mk 2 MR2 reversing lights
Custom rear light units
Custom rear fog – clear led
Pug 206 clear led high level brake light
Aerial moved from wing to roof
18"x8" two piece alloys
5Zigen titanium wheel nuts
JDM Projector Head lamps
12000k HID lamps
7500k PIAA main beam bulbs
PIAA led side lights
NACA side ducts
Aero filler cap in place of oem flap
Interior
Custom 3 gauge centre panel
2 gauge A pillar post
Custom passenger gauge/screen cluster
Momo gear knob
Blue/Black race seats
Blue race harnesses
Apexi RSM mounted in Dash
Remote start button in dash
Climate control unit relocated to centre console
Stripped f/glassed door panels
Stripped f/glassed central cubby
Necvox TV/DVD/CD/Tuner unit
Apexi Commander unit
Apexi shift light
Heads up display
Greddy turbo timer
Skewer custom dials
Engine bay/Performance
Full forged engine rebuild inc:-
APR Head studs
86.5mm Forged pistons (custom J&E)
Oil Pump
all valves recut, reshimmed
head skimmed
block rebored
crank polished
new main and big end shells
NGK iridium plugs
Metal Head Gasket
Chrome Moly lightened flywheel
Uprated sports clutch
Exide Maxima 900DC battery
Cusco front brace
National grooved/drilled discs
Apexi Power FC tuneable ECU
Blitz Nurspec R exhaust
100 cel sports cat (rated to 600 bhp)
Aussie flex pipe
Custom polished Downpipe
Polished Exhaust and inlet manifolds
Fensport Oversized/lightened alloy alternator pulley
Fensport Oversized/lightened power steering pulley
Fensport Aircon removal kit inc lightened alloy Idler Pulley
Turbosmart dump valve
Tein suspension
Polished Rocker Cover
Lagged charge cooler
KOYO all aluminium racing radiator (twin core)
Samco uprated hosing (various)
TRD Radiator and charge cooler caps
Greddy oil cap
Catch can
Custom polished header tank
Greddy TD06 turbo
General
Wizards of NOS purge kit
Remote start pager alarm
Customised st205 oem bonnet
Apexi AVC-R Boost controller in custom pod
Sard 800 injectors
Walbro fuel pump
enroute for 450 bhp once I get time to run her in   :-) :-) :-)
Just one or two mods then  s:wink: :wink: s:wink:
Any chance of some more pics of the car (in a new thread please)?
Sounds awesome from the specs though Perry, must meet up again soon.
perry, I noticed you didn't menton the bearings, do you still have the stock ones?
Have you seen this thread:
 m http://www.spyderchat.com/phpBB/viewtopic.php?t=23193 m
what make of seats are they perry and do they sit higher thn the stock seats?
make not known I'm afraid, got them from a trader on e-bay.  they sit aprox 3/4" higher than stock if you do the runner mod I described.  If you didnt then as with most aftermarket seats they would be a good 2" higher!
on the bearings, yes they have been upgraded as part of the forged rebuild, but the 3SGTE engine from the GT Four is a slightly different kettle of fish than trying to squeeze exra horses from a vvti lump .
The engine is now good to 600bhp, but wont be going past 450 personally
mat post some pics in another thread later if i get the time, way behind at present tho and wont me making JAE as she will be in the spray shiop   s:-( :-( s:-(
You have a 3S-GTE?  s:shock: :shock: s:shock:
Quote from: "Tem"You have a 3S-GTE?  s:shock: :shock: s:shock:
It's not a MR2 Tem, it's a silly-car.
Ohhhh...now it makes more sense  s:oops: :oops: s:oops:
ive fitted some aftermarket seats now but find that Im quite a bit higher and my knees are very close to the steerimg wheel.
The runners are the original ones in the original position...how can I drop the seats down onto it lower?
See Perry's post 11 posts up ^^^^
when I had the 2" steel bar welded across, it was welded on the underside of the existing runner base (if that make sense).  I did try it on top of the runner at first but as you say itys way way to high
Yep 3S-GTE   s;-) ;-) s;-)
sorry Tem, yep its a GT four WRC Celica.  I still have the two as my daily runner at present
Very nice indeedy; must arrange a meet sometime  s:wink: :wink: s:wink:
thats what i was getting at, nice one perry cheers.
