1.8 clutch replacement
Started by MartynMR2, December 12, 2024, 08:30
MartynMR2
Hello all,
So I've been told by "her in pyjamas" that the cars clutch has started slipping...I suspect its been doing it for a while. ::)
Before I start pulling it apart, is there anything to catch me out? seals/ weak points etc
Luckily lots of the surrounding items have been removed/ replaced in the last 5 years so not counting on much that's stuck..
My supplier doesn't list a replacement clutch fork, just the 3 piece clutch.
Any thoughts would be grateful
Martyn
LUK cluthes work very well. Nice and smooth.
bobo83
Quote from: MartynMR2 on December 12, 2024, 08:30Before I start pulling it apart, is there anything to catch me out? seals/ weak points etc
I have changed a clutch this summer using this guide (https://www.mr2roc.org/index.php?topic=61540.0) and everything went relatively smooth.
The only other thing I changed except the clutch was the drive shaft seals. I did not plan to change them but did buy them ahead of time just in case ... and it was a great idea as I ended up damaging a seal when taking the driveshafts out of the gearbox.
Having an (slim ideally) impact wrench with impact rated attachments is a must I'd say.
Good luck.
MartynMR2
Quote from: bobo83 on December 12, 2024, 22:25I have changed a clutch this summer using this guide (https://www.mr2roc.org/index.php?topic=61540.0) and everything went relatively smooth.
Good luck.
Thanks very much
