fitting 6 x 9s
Started by dlivingstone_19, January 14, 2006, 15:48
dlivingstone_19
Has anyone got any pictures of when they fitted 6 x 9s in the rear luggage compartment? How easy is it to do this?
** Racing in the Caterham Academy for 2013 Thanks to Pistonheads, Autosport and Caterham **
Toyota MRS Spec:
Trd front splitter, Trd Side skirts, Trd Rear Spoiler, New style Rear Lights, 17inch Dezent Motion Black Alloys, Cobra Quad Exit Exhaust System, Markiii Inlet Pipe & Sony Cd Player
dead easy, just make yourself a template, wireing can be run down either side easily
dlivingstone_19
right looks and sounds easy. 1 problem though when i bought the car one of luggage covers was missing. do you know anywhere that i can buy this? except from toyota as they want £90 fo it
Toyota MRS Spec:
pm Adam, his username is Jap GT300, he'll more than likely be able to help you
dlivingstone_19
ok have done
Toyota MRS Spec:
Up to how many inches SUB can I fit there? 12" is ok?
Also, where is a good position to install 2 amps?
Quote from: "SimosSpyder"Up to how many inches SUB can I fit there? 12" is ok?
the one in the picture is a 10", but in retrospect i wouldn't fit it to door panels as they arn't solid enough to cope with the bass, a bass box is basically required. as for the subs, there is space either underneath the L/H cubby door floor if you have a manual transmission otherewise its either the wall behind the passenger seat or in the storage under the bonnet
I dont understand where exactly you mean to position the sub.
Do you have any photo of the implemantation?
look further up the post for my installation
Quote from: "kanujunkie"
Do you have any Toyota part number for these ??
I want to buy a spare set for installing the speakers.
You can buy my old ones off me if you like?
Slurpy Much You Selling Yours for???
Would I get decent sount if I just fitted 6x9's in the back and nothing else??? (not aimed for you slurpy)
I reckon you would. Not going to be perfect as seats are in the way, but they will add to the sound from the front and make the whole thing a bit more rounded IMHO.
They sound great mounted in the doors. Mine aren't amplified, either.
think i will give it a go, no amp or sub, should be ok
I'll be doing the same this week. Think I will go for the same sort of angle that Stu has used with his, as the higher frequencies probably have some chance of making it past the seats that way.
Let me know how you get on buddy and how difficult it is to run the wires.
Quote from: "daz8365"Let me know how you get on buddy and how difficult it is to run the wires.
running wires is no worries in the 2, but be prepared for a few skinned knuckles. If you're rewireing the door speakers then get an old coat hanger(the wire type) and cut out a straight length of it, say 1Ft and then bend over the last 1/2" completely back on itself to create a hook, this can then be used to pull a piece of string through the rubber door wire guide. That string can then be used to pull a wire through.
Useful tip Stu.
Daz, hopefully not too much bother as all the interior is out at the moment.
