Angpozzuto
Quote from: 1979scotte on March 24, 2018, 13:28
Quote from: Topdownman on March 24, 2018, 08:16
I am running 195 and 225 on mine, cant help but think you should be too!
If you went to FL 16" rear wheel you may get less tyre "squat" under acceleration?
It wasn't the tyres it was the dampers they're in a very soft setting.
I have FL wheels in the loft but I will wear out these tyres first.
Even then not positive I will go to FL wheels so much more playful on the smaller ones.
there's a very fine line between playful and facing the wrong way at a roundabout [emoji50][emoji90][emoji90]
Quote from: Angpozzuto on March 24, 2018, 14:31
Been there done that.
Was on old tyres with fresh coilovers in my MK3 turbo.
Fitted at a mates place first roundabout I came across.
It obviously went straight in for a full 4 wheel alignment asap.
As well as new tyres.
MR TWO
Quote from: 1979scotte on March 23, 2018, 22:04
Quote from: MR TWO on March 23, 2018, 21:54
Quote from: 1979scotte on March 21, 2018, 20:42
Home.
It's bloody quick.
Too quick for the road if I am honest.
Makes some interesting noises.
And the rear dampers need firming up because she squats down like an American muscle car under WOT.
I've thought that a few times about vechicles I owned, usually just after purchasing, or adding some extra ponies.  Its a feeling that always went away!
Pretty sure the feeling will go away however the Speedo and the smell of the breaks pads won't.
Not had it up to 6 psi since the day I bought it home. 5.05 psi just now.
Love the noise. Not the V6 the Rotrex. It just sounds so futuristic.
I can't wait to hear it myself!
Had a bad night last night so got up around 4am.
Started trawling through the manual of my ECUmaster Det3 piggyback.
Wanted to investigate some of the advanced features.
First off fuel implant mode. This is where it acts more like a standalone and takes full control of the injectors stopping the stock ECU interfering.
After a quick read realised that it's a bit beyond my meagre capabilities and moved on to looking into boost control.
And this bit was disappointing. On a 6 cylinder application it can't fully control the injectors and a boost solenoid. One or the other. On 4 cylinders it would be fine.
So I am now thinking try and get it take full control of the injectors and buy a separate electronic boost controller. Have been looking at the gizzmo icb-r. It will reference rpm against boost so you taper it off at high rpm like SP did in their turbo kits.
I was being sent down the route of apexi avcr by another outfit. Apparently still one of the best ones.
By gear, by speed, tail off, different profiles etc etc.
As they're old you may be able to pick one up affordably.
Quote from: shnazzle on March 26, 2018, 12:01
Brand new they are so expensive. Didn't think about a pre loved unit.
m1tch
I had an AVCR in my RX7, good bit of kit as it learns boost by gear and also had a 'scramble boost' option so you can set a base level of boost but then press a button and it would then up the solenoid duty/boost for a set period of time.
tomaky
Westfield Seiw
Ex - 2005 Porsche Cayman S
Ex - 2003 Sable
Ex 2004 Blue  Roadster RIP
Quote from: tomaky on March 26, 2018, 13:33
This is the GFB one i had
https://www.demon-tweeks.co.uk/Product.do?method=view&n=531&p=224882&d=124&c=4&l=2&utm_source=Google&utm_medium=Base&utm_campaign=Boost%20Control%20&%20Electronics&gclid=EAIaIQobChMI9Mz0uv-J2gIV7zLTCh0IqgjDEAQYASABEgK49PD_BwE&gclsrc=aw.ds
Might car mods have a installation and testing video on it ;)
Twas the first one I considered.
It doesn't reference rpm so it just a constant boost level.
I would like to have say  7.5 @ 4500rpm then drop down to 7 or whatever is deemed safe close to max rpm.
tomaky
Fair enough, i had the gen 2 is the gen 3 any better?
Westfield Seiw
Ex - 2003 Sable
Quote from: tomaky on March 27, 2018, 07:47
Think that just incorporates EGT which I have if I want it.
48L fuel tank = 10.6 gallons at 22 mpg = not that much.
Hopefully get up to 30 mpg on the motorway today.
Unlikely but a man can dream.
chasmundo
Quote from: 1979scotte on March 30, 2018, 08:59
22mpg traveling at light speed with a big smile
May get 30mpg if you slow down to 65mph.
Hopefully not too much bank holiday traffic for you.
Enjoy
tomaky
Westfield Seiw
Ex - 2003 Sable
chasmundo
Quote from: tomaky on March 30, 2018, 09:13
Ive got 14 mpg this week ha
You must have a hole in the petrol tank.
14mpg !!
That does happen, in my case on a '56 Beetle though.
MR TWO
You keep driving & dreaming, though not at the same time.
chasmundo
Quote from: Joesson on March 30, 2018, 12:09
Great taste '56 beetle
One of my regrets not owning a classic beetle with uprated engine
tomaky
Quote from: chasmundo on March 30, 2018, 09:15
14mpg !!
Ha its too and from work its only about a mile but its stop start.
3.4 litre and a new exhaust doesn't help either ha
Westfield Seiw
Ex - 2003 Sable
Quote from: tomaky on March 30, 2018, 15:21
3.4 litre and a heavy right foot to make the new exhaust 'bwaaaarp' doesn't help either ha
Fixed that for you mate.  :D
That's going to take some careful route planning, maybe we should incorporate an annual fuel spend into the numb bum award too?[emoji23]
tomaky
Westfield Seiw
Ex - 2003 Sable
Quote from: MR TWO on March 30, 2018, 12:20
Check my fuelly.
Got over 29mpg on the motorway.
