Removing passenger seat - any warning lights?
Started by m1tch, June 29, 2017, 21:07
m1tch
Hi all,
I will be looking to remove the passenger seat in the car at some point for weight reduction, I am just wondering if there are any sensors or anything I should be aware of when removing the seat. I know that some cars have connectors that you need to fit a resistor to otherwise it flags up an airbag warning which is an MOT fail. Before I take the seat out I just need to know if there is anything I need to do to avoid any issues with the MOT around warning lights or are the seats just a standard 4 bolt and remove job?
It is certainly just 4 bolts and then unplug the sensor connector underneath to remove.
I havent driven with it out but cant see there would be a problem?
m1tch
Quote from: "Topdownman"It is certainly just 4 bolts and then unplug the sensor connector underneath to remove.
If the sensor is there to check for a passenger and the ECU doesn't detect enough resistance it might think the sensor has gone bad and won't arm the airbag system and throw a code and light on the dash - usually these can't be reset by the normal OBD2 readers. I have a feeling that I need to get a 3.3 Ohm resistor fitted to fool the ECU - can anyone confirm?
mikek
No problems unplugging the sensor, I've driven with no seat on quite a few occasions.
New little car to follow soon
Ex 2zz by Rogue. Se7en cams. BMC CDA. Competion clutches lightened flywheel, Megillian Racing Exhaust. TRD sportivo suspension and ARB\'s. TRD braces. TRD quick shift. TRD dash kit, Matts brace. Getting there but not sure when it will stop!
m1tch
Quote from: "mikek"No problems unplugging the sensor, I've driven with no seat on quite a few occasions.
Would I need to go to a dealer to reset the airbag light if it does come on? Just concerned its going to cause issues with MOTs etc.
mikek
Never had an airbag light come on. Driven hundreds of miles with the seat out when picking parts up etc. Never had any issues.
Doesn't the wire to the seat just work the passenger seatbelt warning light?
The Other Stu
Both my seats are disconnected - I have S2000 seats.
Isn't causing me any problems.
I believe the sensor is there to make sure if someone is in the seat, the seatbelt is clipped in. Certainly that's the case with every other car I've had.
MR TWO
Quote from: "The Other Stu"Both my seats are disconnected - I have S2000 seats.
Same with my car, unplug and forget about it.
m1tch
Thanks guys, will just disconnect it and see what happens, I know some systems ensure that everything is working correctly and if its not 100% perfect it throws a code.
Quote from: "MR TWO"
Unplugged mine too as kept flashing at me when I had a bag or something on passenger seat without seatbelt attached, no issues.
The Other Stu
Wait until you get one like my old Mokka or current car which screams at you if it thinks there's someone in the passenger seat!
ad_car_08
Removed my seats and now got an airbag light constantly flashing at me and I can't turn off, so be aware!
Tried the resistor trick, to no avail. I think there must be a certain process you have to follow
[/size]
Quote from: "ad_car_08"Removed my seats and now got an airbag light constantly flashing at me and I can't turn off, so be aware!
I know I disconnected the battery before I took mine out to swap the seat backs, wether that's relevant or just coincidence?
m1tch
This is what I am concerned about, its usually impossible to turn off unless you have dealer software, its an MOT fail if it doesn't come on then go off afterwards (showing the system is ok) - really don't want to trip the airbag light.
ad_car_08
Quote from: "Call the midlife!"
Ignore me, taking my seats out was fine, it was when I disconnected the airbag to change the steering wheel when I got the airbag light  s:lol: :lol: s:lol:  sorry!
[/size]
m1tch
Phew, will try it a bit later then and see what happens!
