Rear Sub Frame - Where to find one
Started by bap_swcc, December 13, 2017, 13:09
bap_swcc
Hi guys, I know this has been covered but looking for some up-to-date advice as previous threads mention companies that no longer exist etc.
I need to replace my rear subframe (2004/5), any companies or affiliates on here that can get hold of them, and does Toyota still do them or are the rumours of them being discontinued from Mr T true.
If i buy an old pre facelift one I believe it doesn't have the same bracing holes, is this bracing something I can just leave off?
Or anyone on here with a facelift one for sale? I have seen Krazy Steves post for a preface lift one.
The Notorious B.A.P.
2004 Black 2zz - I believe in lift power!! (although I do miss the quality woosh of a turbo)
mikek
Just under £300 from toyota
New little car to follow soon
Ex 2zz by Rogue. Se7en cams. BMC CDA. Competion clutches lightened flywheel, Megillian Racing Exhaust. TRD sportivo suspension and ARB\'s. TRD braces. TRD quick shift. TRD dash kit, Matts brace. Getting there but not sure when it will stop!
JoeCool
try Dick Sloan via the Facebook Group 'MR2 Roadster Club'.
2ZZ '02 Roadster
krazysteve
Carl at Raven has some Face lift ones, freshly powdercoated in a choice of colours.    m https://www.facebook.com/Ravenltd/ m
RACING, because football, cricket, rugby and golf only need ONE BALL
bap_swcc
thanks guys
m1tch
Its worth noting that the new OEM ones from Toyota will rust exactly the same as the one you are replacing - best to go with a recon subframe that has been treated etc so you won't need to worry about it in the future.
Quote from: "m1tch"Its worth noting that the new OEM ones from Toyota will rust exactly the same as the one you are replacing - best to go with a recon subframe that has been treated etc so you won't need to worry about it in the future.
They're also black instead of silver on the outside for some reason.
Sent from my SM-G930F using Tapatalk
krazysteve
Quote from: "onion86"
over 6500 colours to choose from lol, even has some luminous powders.  m https://www.facebook.com/Ravenltd/posts ... 3490730693 m
Quote from: "krazysteve"
I meant the one from Mr T.
Bossworld
Has that been proven?  I bought a brand new one from Toyota for £300 (black) and Hammerited the  sshit shit sshit  out of it as a precaution.
I then (very fortunately) found someone selling one that had been purchased from Toyota in recent years (black one) along with both sets of arms for an unbelievable £50, which has gone on mum's MR2.  But, not a speck of rust on it despite it not having been treated/coated (I coated it before it was fitted to hers).
stavros58
Hi I had one fitted about 4 months ago it cost just short of £300 plus fitting, then had to get ATS to re-track front and rear another £50. My garage had no problem getting the sub frame from Toyota drives really well after the re-track as well plus I had a new clutch put in so i did feel a bit skint after, £700 + poorer but then Toyota charge £700 just for a clutch so I'm not moaning.
MR2 Chilli Red, final 300 production run for U.K. Hard Top, TTE twin pipes, Alacantra leather. Pre registered, no mods but  Brilliant! Favourite quote "I don\'t expect to know what is around the corner but I do at least expect to know where the corner is"
DimitriMR2
new one from Toyota as mine was rotten through,
£300 from toyota plus fitting,
didnt coat it,
if first one did 2003 -2017 I think the rest of it will have fallen apart long before the other one goes through!
Quote from: "DimitriMR2"new one from Toyota as mine was rotten through,
didnt coat it,
Up to you mate but had one that didn't even last 10 years.
I will be keeping my 2 for as long as possible and as these parts are no longer made it makes sense to take preventative measures.
