2000 golden brown money pit
Started by FredyCro, July 30, 2020, 21:07
FredyCro
#100
if I can, Yes. Lots of things changed in last year or so, my life is in constant turmoil. This car makes me happy, its my happy mobile. If I sell it Ill for sure get a new one once I settle and create a pure track car.
Latest photo
large image upload
IG: optimal_zzw30
FredyCro
Does anyone knows how much can safely 1zz cylinder head can be trimmed? Ill probably do a small scale engine rebuild to freshen it up and would like to know this to get the right info to the machine shop.
Anybody did a crankshaft lightening, balancing (knife edging) on 1zz? I can do it fairly affordable at a great quality, stock is heavy.  And cons?
Any engine pulleys that are safe/ recommended to be made out of aluminum?
Ill probably go to force induction (SC most likely) if I dont sell the car or do some other swap - this is the prep work that needs to be done and why not do this while engine is down and being disassembled.
Thank you!
IG: optimal_zzw30
FredyCro
Did a professional photoshoot the other day, looks really good :)
IG: optimal_zzw30
AJRFulton
Gibla
Stunning looking car, just a point I have the sc car that Carolynne built, it is roughly 185-190 bhp using the  M45 Eaton sc ex mini-cooper s with a 'lengthy' belt, shorter belts can yield even more power(not an option or avenue I will consider).
You are discussing skimming + lightening for marginal benefits(with some risk of over-doing it) to gain how much bhp? Whatever the # is, it pales into insignificance if you do go down the sc route. Maybe as Carolynne did, refreshing the engine internals would be the advisable option eg new pistons + honing?
2001 Dark Green MR-S (6R4)
FredyCro
Quote from: Gibla on April 18, 2022, 14:18Stunning looking car, just a point I have the sc car that Carolynne built, it is roughly 185-190 bhp using the  M45 Eaton sc ex mini-cooper s with a 'lengthy' belt, shorter belts can yield even more power(not an option or avenue I will consider).
In a few weeks time car is going for an upgrade, just took my old cylinder head to the shop for headwork today. Besides that we will change piston rings etc. All of this should give me a small increase in power plus a piece of mind. After that plan is to sort out the exhaust, complete new components from headers on. Beyond that ecumaster det3 probably.
If I decide to do a pulley from aluminium it will be sort of a side thing.
SC - amybody knows of any good kits or can build one to order?
And constant hunt to lightened the car without making it look modified in on :) If I opt for a single bucketseat with a hard top down Ill be below 900 kg for sure as it stands now. That with a healthy amd slightly upgraded engine should do me fine :)
IG: optimal_zzw30
Lightning the things that go high revs is véry worthwhile. It is all about moment of inertia; MR2. It does not produce any more hp but it sure frees the up.
A lighter flywheel lighter pullies, gearing down the alternator are very effective as it is power not spent on accellerating/decellerating internal mass. The order of it you can relate to the wheels times the overall reduction of the gear you are in.
A sc will ádd a considerable rotating mass. It adds a case of the dog chasing it´s tail.
That observed a sc is imo the most effective way to get to the level of power you mention and I would LÓVE one on mine, but you see it needs to also compensate it´s own inertia?
Toyota themselves btw., made plenty of use of superchargers in the eighties/nineties. In the MR2 they used the SC12 which they also fitted to the Levin. In the Previa they bolted the SC14. The latter gave 170-180 hp. and would probably the best for the ZZW30 because it would operate at nicely low revs, generating less heat/losses. Imo Toyota would have gone this way like the did on the Corolla T-Sport which they gave an Ogura TX-12.
The 12 or 14, line the 300 or 500 on the Aisins, is a metric value for the swept volume per revolution.
The 12 being 1200 cc. and the 300 being 300 cc.
Eaton is in cubic thumbs of feet and the Eaton62 sweeps 1 metric litre, 1000 cc, per rev. so that would be an SC10.
Here the AW11 install
FredyCro
Did some spring cleaning yesterday
IG: optimal_zzw30
FredyCro
Had a spare head, gave it for a bit of a nip n tuck. Will put it in eventually, hopefully with som exhaust ECU work afterwards
IG: optimal_zzw30
Quote from: FredyCro on June  5, 2022, 11:54
Not such a popular thing to do in recent times, a de coke, valve seating and some porting work was the way to go at one time. With more alloy heads nowadays, improved OE design and production, likely less need but I would think such work on what now must be an old head, must be for the good.
FredyCro
Car has been sold, best of luck to the new owner with his upgrade plans. Should be interesting if he executes them
IG: optimal_zzw30
Do you plan to get another one or are you moving on to something else?
FredyCro
Quote from: Topdownman on October 17, 2022, 07:13Do you plan to get another one or are you moving on to something else?
Hi, been back to the forum as Im looking into moving my to Andalusia and remembered @Petrus posted extensively about it. Will go over it again to refresh my memory but liking the idea so far.
My life took a significant turn since my last posts, suffice to say it was for better even though it was very challenging at times. Hopefully Ill execute on my plans and will relocate before 2030.
Ive went the EV way taking on tesla modele 3 performance ownership (pardon my French regarding this forums census I assume :D ). Its a blast especially with all my newly created energy universe around me but zzw30 had left a fond memory in my heart, its been there for me during my times of sorrow and its been a source of joy for me and my daughter, I tend to own it once again enriched by my first ownership experience.
Maybe even a buyback option for my original car in possible as AFAIK my original car is collecting dusk in a garage not far from me. It is very very low on my list of priorities for the time being so Ill look into it after sorting other.
Fond to be back unintentionally, thank you all for your kind words in this forum topic :)
IG: optimal_zzw30
